Larger-format CNC router with a 500W spindle, dual linear rails, and ball screw drive
Use with Easel Pro →
The 4040 CNC Router Machine, 500W has a 400 x 400 x 95mm (15.75 x 15.75 x 3.74 in) working area, a 500W spindle running 12,000 RPM, dual linear rails with a ball screw drive, and a NEMA23-76 closed-loop stepper motor.
This 500W spindle runs at 12,000 RPM, in the middle of most of the chart below, so you have solid speed available across most materials. This is the most rigid of Vevor's smaller CNC routers checked here: it runs dual linear rails with a ball screw drive and a closed-loop NEMA23-76 stepper motor, the combination that lets a machine hold a deeper cut without the bit deflecting. Depth per pass is still governed by the same rule: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This machine has more of that than Vevor's lighter routers, but it is still a desktop machine, not an industrial one, so build up gradually rather than assuming full-diameter passes from the start. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, but this spindle tops out at 12,000 RPM, so run 12,000. With the bit maker's 0.025mm per tooth (0.0010 in): 12,000 x 0.025 x 2 = 600 mm/min (24 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Vevor 4040 CNC Router Machine, 500W runs GRBL 1.1 firmware, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Vevor 4040 CNC Router Machine, 500W in Easel's machine menu to size the canvas.
Try Easel Free →
Easel Free Trial →
