Ben Uyeda Outdoor Lounge 1x6 V2by Ben UyedaOutdoor Lounge Chair
A full-size lounge chair made from 1 × 5½-inch deck boards. The shared files shape the side frames; plan the slat length, board count, joinery, and outdoor finish before cutting.
For the campsite, patio, or next trip
Build a lounge chair for the deck, a camper sign, or a piece for your next trip. Adapt the size, material, and finish to where the project will live.
Creating an Easel account is free. No credit card required.
Start with the destination
Outdoor projects have to solve more than a visual problem. A chair carries weight, a campsite sign needs to read from a distance, and anything left outside has to handle moisture, sun, movement, and repeated use.
Begin with the place and purpose, then choose the project. That keeps the design focused and makes the material, joinery, bit, and finish decisions easier to test before the final cut.
Real projects from the Easel gallery
Each published project has a working preview and copy path. Open one to inspect the design and toolpaths, then adapt the dimensions, stock, lettering, and finish. The signs use V-carving, which requires Easel Pro; you can start with a free trial.
Ben Uyeda Outdoor Lounge 1x6 V2by Ben UyedaA full-size lounge chair made from 1 × 5½-inch deck boards. The shared files shape the side frames; plan the slat length, board count, joinery, and outdoor finish before cutting.
Adventure Signby Sam AlaimoA carved MDF sign with bold outdoor lettering and a shaped profile. The maker used a V-bit, sanding sealer, black paint, and surface sanding to keep the fine details crisp.
Camper signby James StewartA layered birch-plywood camper sign with an editable name. The design uses a 90-degree V-bit for the face and a ⅛-inch bit for the cutout, then adds paint for contrast.
See more outdoor recreation search results →
From the makers’ comments and project notes
Read the project comments without an account. Log in to post a question in the project discussion; replies are not guaranteed.
Sam Alaimo engraves the Adventure Sign lettering first, then switches to the next workpiece to cut the outline. Keeping those steps separate lets you finish the fine lettering while the surrounding board still holds the sign. Follow the project sequence before moving on to paint and sanding.
Project notes by Sam Alaimo: read the source.
From Adventure Sign by Sam Alaimo.
Ask a questionStart with a real community project, adapt it for your campsite, patio, or next trip, and prepare the design for your CNC in Easel.
