Personal details for the wedding day
Make CNC wedding signs that fit the celebration.
Start with a real Easel project, add the couple's names or date, and plan the material, bit, and finish before you carve.
See the real projects
Choose the job before the style
Design for where the piece will sit
Wedding pieces do different jobs. A welcome sign should be readable from across the room, a keepsake can focus on names and a date, and table numbers need to stand securely without crowding the place settings.
Choose the setting first, then match the project to it. That choice sets the size, material, lettering style, bit, mounting method, and finish. The examples below cover a square personalized sign, a long hardwood date sign, and freestanding table numbers.
Real projects from the Easel gallery
Three wedding projects you can customize
Each project has a working preview and copy path. The two personalized signs use V-carving, which requires Easel Pro. The standing table number uses a straight end mill and a fitted base.
See more wedding sign projects →
From the makers’ comments and project notes
Keep stained wood and painted lettering crisp
Read the project comments without an account. Log in to post a question in the project discussion; replies are not guaranteed.
Protect the stain while removing excess paint
Sam Alaimo recommends extra layers of stain and sealer, followed by light sanding to remove paint from the face. If sanding removes some stain, he suggests touching it up with a small brush that avoids the painted lettering. This gives you a way to preserve both colors instead of sanding the whole face aggressively.
Comment by Sam Alaimo: read the source.
From Customizable Wedding Sign by Sam Alaimo.
Ask a question
Make your own CNC wedding sign
Start with a real community design and personalize the names or numbers in Easel. V-carving requires Pro.
