A game board for the table or the road
Make a Mancala board for game night.
Start with a real Easel project, then check the pit layout, stock, and workholding against the stones and machine you plan to use.
See the real projects
Start from a blank workpiece
Design your own Mancala board
Draw a rounded board outline in Easel, arrange two rows of six round pits and two long end stores, then turn the 3D preview to see the layout.
Recorded in the Easel editor, playing at 8× real speed.
Real projects from the Easel gallery
Carve a tabletop board or put Mancala inside a travel case
Compare contrasting wood strips, a folding game case, rounded bowls and spiral-cut pockets. The project descriptions explain which files contain editable layouts and which use imported machining code; details such as inlay, assembly and board alignment still need your own planning.
See more Mancala projects →
From the makers’ comments and project notes
Details to use in your own mancala boards build
Read the project comments without an account. Log in to post a question in the project discussion; replies are not guaranteed.
Use two light finish coats on the folding game case
joshua blom finishes the sanded game case with two light coats of spray lacquer. His notes describe this as the final surface treatment before play. Keep the finish thin enough to preserve the carved pocket shapes rather than filling them with a heavy coat.
Project notes by joshua blom: read the source.
From Contest Entry: Wooden Marble Game Set by joshua blom.
Ask a question
Make a board your family can play
Open a real Easel project, check its design against your stock and stones, and create a free Easel account when you are ready to make a copy. No credit card is required.
