Hint: Recommended cut settings are dependent on both the chosen material and the chosen bit
3d easel
Hmm...there should be a 3D preview here.
The 3D preview relies on WebGL, a new graphics technology that's available in the latest versions of all the major browsers.
  1. Choose "Preferences" from the Safari menu.
  2. Click "Advanced"
  3. Check "Show Develop menu"
  4. Now go to the Develop menu and click "Enable WebGL"
Not using Safari? Click here for advice for other browsers
WebGL is enabled by default in Chrome for most recent graphics cards. However, there are some cases where WebGL may not be available. See Chrome WebGL Help for more information.
Not using Chrome? Click here for advice for other browsers
WebGL is enabled by default in Firefox 4 and higher. If webGL is not enabled, you can enable it manually:
  1. Go to "Preferences" under the Firefox menu
  2. Click "Advanced"
  3. Under the "General" tab, check "Use hardware acceleration when available"
  4. Restart Firefox
Not using Firefox? Click here for advice for other browsers
WebGL is only available for IE 11 and higher. You'll need to either upgrade to IE 11 or try a different browser, like Google Chrome.
Not using IE? Click here for advice for other browsers
